rkentzel
Sep 14, 2015Explorer
You all better be careful driving screws around the edges of these refer boxes you hit the hot gas bypass loops and your done. Not repairable and no warranty will cover it.
go for the frame on the bottom if you insist on the top use long l brackets or 2x4 just above the top of the refer before you slide it. keeps it trying to tip forward and some in the frame front and back wont go anywhere.
Even if you have a plumbing diagram it does not mean its in the right place when they foam it in the tubing can move a bit.
