Sprig
Oct 07, 2012Explorer
donn0128 wrote:
Many oven doors are designed with a latch to lock it partially open.
:? I can see this for a Fridge door, but really does not seem to make sense on an oven.
donn0128 wrote:
This allows you to lift it off and replace it without loosing the spring. Look to see if there are latches on the hinges.
Why would I want to remove the oven door?
Again, I can troubleshoot the problem by thoroughly investigating the unit and find a solution for myself. That would include "looking" at the hinges after I took the door apart...
Remember the "wheel" comment in my OP???
38,782 PostsLatest Activity: Sep 10, 2026
