John_Joey
Jan 22, 2015Explorer
Kenmartin1 wrote:
Atwood g10-3e no power at switch or outside at unit, but fuse is good. Does anyone know if the power goes through the switch before going to unit? Could my switch be bad? It's the type of switch with the red light that let's you know when it's lit. Thanks Ken
That's what was the problem with mine. If there is power to the switch, but none to the heater then it's more then likely the switch. When I bought the new switch I found out that they are 15 amp yet the circuit is 20amp. Might explain why the old switch went bad.
Sorry just read you do not have 110 but only 12v. Your 12v switch still might be bad though. That is easy to check. Just disconnect the leads and test for continuity with the switch on and off. 5 second job.
38,766 PostsLatest Activity: Jan 10, 2026
