dougrainer
Jun 18, 2013Nomad
1. There is no reset for power loss on Atwood Electric levelegs
2. Losing power to the Atwood system will NOT cause any problem
3. I have NEVER heard or seen any control board other than the original models that Atwoods have always had
4. You may have a problem with your Atwood jacks, but it was not caused by your Converter issue. Below is the only reset and does NOT take 2 hours ($200). Doug
5. NO CURRENT ERROR MODE
• During any operation if no current is detected from leveler after
leveler is activated, the following occurs:
1. Warning alarm will sound.
2. Power is removed from the control box disabling normal
operations.
3. The red and green LED’s for that leveler will blink on and off
to indicate the system is in an error mode.
• To proceed,
1. Press “ON”. This will shut the warning alarm off.
2. Simultaneously hold down all four direction buttons and the
“All” button. This resets the timers so controls will detect the
next clutch.
3. Press “RET” and “ALL” buttons. The system is now out of
error mode and ready for normal operations.
If step 3 does not fix the problem, individual levelers can be
retracted by simultaneously pressing the “RET” button and the
adjacent two (2) leveler buttons common to the leveler requiring
retraction.
operations.
• To proceed,
next clutch.
retraction.
38,782 PostsLatest Activity: Sep 10, 2026
