Teacher's Pet wrote:
FYI New generation Levelegs work with the old and new control board. I have 3 new generation Levelegs at the present and one 1st generation. We have changed 4 legs so far with 2 being under warranty. If our board fails I've been told it would amount to 1 leg, a current generation control board and some additional wiring. But then again that may have changed.
The OLD jacks have a 2 wire motor harness. The NEW jacks have 4 wires. 2 for the motor and 2 for the rev counter. When you install a NEW style on a OLD system you do not use the Rev counter 2 wires. But, if you installed a NEW style control board, it would require all 4 jacks to be 4 wire and you would have to run those extra 2 wires to each jack and then to the new control board. Doug
