Bruce_Brown
Jun 17, 2016Moderator
Mike,
If you're that far out of level any automatic jack would have lifted the rear wheels. If we're in a spot that I think might be trouble I simply hit the "extend all" button, let them each take a set, then I'll finish up as well as I can manually. I hate lifting any wheel off the ground.
If your computer is out of wack and needs to be recalibrated it's real easy to do with that system.
One thing I found helped a lot was manually dumping the air before going into automatic mode. It seems to level better and is more stable. Sure it dumps as soon as you hit the level button, but it seems the jacks are on the ground and working before all the air is gone. Manually dumping it first takes care of that.
38,782 PostsLatest Activity: Sep 10, 2026
