werni9
Dec 04, 2014Explorer
Atwood water heater GCH10A 3E
Gas side has hot water. Electric stopped heating. Things done in this order: Breaker was not tripped and tests good. Switch tested good. The ECO side of ECO/T Stat was original, loose, looked worn out and I replaced it with new kit. Cleaned all terminals and checked wires and fuse. Still no heated water on electric. I changed a check valve on the back 6 months ago (A BEAR in a Winnabago), so taking it completely out again will be easier. YES, I'll check for things I may have bumped around. Funny how you need to go back and fix something that was fine before you got in there. Headed for the Heating Element (screw in) next. Sound about right so far? It's a 2000 Ultimate Advantage. Last time I flushed the tank, I really worked around in there. I had it completely out and was able to actually empty all the bottom chunks out. There were calcium chunks that looked like 1/2 a plastic straw. Farley thick pieces. Perfect fit and look to be around the element. Sorry for mumbling along. So Far, so Good??? Any tips.
