Old-Biscuit wrote:
enblethen wrote:
The receptacle should be hot all the time from the 120 volt AC power distribution panel.
Some rigs have this receptacle ran through a GFCI receptacle. Locate your GFCI receptacles and check to see if one is tripped.
Have you reset your circuit breakers? Turn off all circuit breakers applying light pressure toward off. Then turn on main circuit breaker if equipped, and then each of the branch breakers one at a time.
Get one of the small normally yellow circuit analyzers that plug into the receptacles to identify what is issue.
X2^^^^^^^^
Your vintage uses 120V AC directly to water heater element.
So if no 120V at outlet circuit breaker is tripped OR GFCI is tripped that feeds that outlet.
IF CB/GFCI tripped could be because WH electric element has shorted.
I found that one of the wires in the control box doesn't get 12 Volt
It could be a ground problem. There is also a faulty toggle switch.
I will change the switch and checked again.
