twobags's avatar
twobags
auto brake light
I have a 2004 Allegra,on a workhorse chassis,that has the auto brake system,on our last trip the "auto brake" light began to stay on although the brake itself releases normally,has anyone else ever had this problem and if so how did you correct it? Thanks for any help. Twobags
  • Gjac's avatar
    Gjac
    Explorer III
    Yes I have had this problem and to correct it I had to replace the grey switch which controls the light. If the green switch goes bad(leaks) the light will come on but so will the emergency brake. If you search "Auto Park library" here you will find Rogers documents and how every thing works.
