Cindy_and_Steve's avatar
Oct 23, 2021
Automatic air tank drain valves
I tried to drain the water from the air tanks on our RV and I couldn’t find the drain valves. No valves to turn and no lanyards to pull. On the tanks, where drain valves should be, are some sort of gizmo with an electrical connection. Could they be some type of electric drain valves? If so, how do you operate them, or are they automatic?
  • I am assuming you have a HWH auto level system. If so it dumps the air before it starts to level. Quick way to see is store the level and build pressure and then have someone outside and level the system. Air should be dump if not then the level system should not work.
  • google 12 volt air dump valves and you will probably find the one you are looking at on your tanks
  • chuckftboy wrote:
    Look a little closer. My lanyards were ty-wrapped to my frame and I had to cut the ty-wraps and stretch them out through the frame. That's probably how mine left freightliner and neither Winnebago or General RV took the time to do a very good PDI.
    I layed right under the tanks and stared at them. There are no lanyards and no drain valves to open.
  • Look a little closer. My lanyards were ty-wrapped to my frame and I had to cut the ty-wraps and stretch them out through the frame. That's probably how mine left freightliner and neither Winnebago or General RV took the time to do a very good PDI.
