bluwtr49
Nov 01, 2014Explorer II
RoadAbode wrote:
As we age we learn that the way we do some jobs change. We learn new ways to do old things. In the end, using the right product will be better for all.
So let's learn about why automotive antifreeze should not be put into our sewer systems or watersheds:
From the EPAAntifreeze is toxic to humans and animals. Waste antifreeze contains heavy metals such as lead, cadmium, and chromium in high enough levels to potentially make it a regulated hazardous waste, so most states strictly regulate antifreeze disposal. Antifreeze generators and state and local programs should not dump spent antifreeze on land or discharge it into a sanitary sewer, storm drain, ditch, dry well, or septic system; dumping antifreeze can cause serious water quality problems and might harm people, pets, or wildlife.
Is wastewater treated? Yes, it is treated in order to reduce the hazards of the infectious agents that are in it. Waste water is not treated with the intention of neutralizing industrial chemicals, and in fact, disposal of industrial chemicals will frequently cause harm to the equipment that is used to treat waste water.
It is very naive (and dangerous) to assume that all of our waste water treatment plants are set up to neutralize any substance that someone chooses to dump into a septic or sewer system.
While your information is accurate for waste antifreeze, it's less so when used in the application as stated. The absence of the heavy metals completely changes the situation. EG is completely bioderagable in a waste water treatment plant.
