Budsmith
Jul 17, 2013Explorer
Aux start not working
I had a low battery on the 2003 winnebago adventurer, so I tried to start with the emergency start swith...I did not get any power..Where should I start the troubleshooting??Bud
wynnd wrote:Just had a similar experience with mine not starting with the ign turn on steps would not go out. I new batteries were good and replace both solenoids within the last several years. When I hit the aux start the eng barely turned over. Turned out to be the HF battery cut off on my eng battery was corroded and arcing. Cleaned and all was well again. Let us know what you found out.
Had this problem once on my Fleetwood gasser...turned out to be a corroded negative terminal on the chassis battery.
Good luck with your troubleshooting!
