Biggyniner's avatar
Biggyniner
Auxillary Start/battery solenoid
Hi All..
I think I know the answer but I'm open to feedback/suggestions...
So I was doing some testing to my Minnie and come to find out the engine is not charging my house batteries. If I depress the AUX start button I hear an audible click, so I believe the relay works in that regard. I tested the house battery solenoid with the engine running and I do have ~14.5 volts on the chassis side of the solenoid and then just 12.8ish volts on the house side - the same amount that was there with the engine off. The generator/shore power will charge the house battery.
Before I swap the solenoid out is there anything else I should check? I hear there should/could be a fuse somewhere for this solenoid, would it be in the chassis fuse panel?
Thanks
