Biggyniner
Jul 28, 2015Explorer
ron.dittmer wrote:
I believe motor home battery charging is prioritized such that the chassis battery will get charged first, then switches over to the house batteries. If your chassis battery needs to be charged, then you will get the measurements you are seeing.
I was curious about that.. My father had an isolator in his pickup for his truck camper that worked as you described... but I believe on my system it should pass the charge through to both batteries anytime the engine is running. I forgot where I heard/read this....
