We have a 2021 bounder 33c we put a carefree eclipse awning on. It is hardwired when the house battery and aux on it starts beeping every 30 sec how can we stop it.
You don't state what model and options you have with the Eclipse. IF you have the BT 12 option. Doug
If the motion sensor batteries are low, the awning will beep every 30 seconds (when the power switch is ON) and the awning will partially retract. This will continue until the batteries are replaced. The awning will operate normally after the batteries are replaced.
