Snomas's avatar
Snomas
back up camera CRT screen failing
My 5" CRT back up screen is only working intermittingly. I have to jiggle a button on the screen to get it to show a picture. Could there be another problem besides the screen I should check for. I feel the camera is OK.
  • Contact RVcams.com. There are replacement LCD screens and adapters to use your old cables available.
  • I have wondered if their's a lcd replacement with a similar mount for those, mines a crt also and a 2000 mod
  • DrewE's avatar
    DrewE
    Explorer III
    If jiggling the screen unit makes it work, more than likely the cause is a loose connection (such as a cracked solder joint) in the screen unit. A competent electronics repair place should be able to fix that fairly readily, assuming they can find it. If you're reasonably handy with a soldering iron, reflowing the joints for through-hole parts would not be a bad idea, bearing in mind of course the high voltages involved with a CRT. (They can store a high voltage charge for quite some time in the flyback circuit after power is removed.)
    It may reasonably be a connection to one of the cables at the screen or a faulty cable at the connector. Jiggling the wires should show that if it's the case.
