NaViDa
Dec 17, 2013Explorer
fcooper wrote:
Agree that you can easily drive the coach without the backup camera working. If you have to back into a place when you get it home, you can get out and look several times.
That camera/monitor will probably be an Intec system like I removed from my Holiday Rambler when it died. If checking cable connections, fuses, power connections, etc. does not fix the problem, just plan on replacing it. Replacement cost if you do the work will be under $200.
When/if you get to that point, send me a private message with your email address and I'll email a word document showing the steps required to remove/replace the monitor/camera.
Fred
Okay, thank you!
