MrWizard
Feb 10, 2017Moderator
lacofdfireman wrote:
My 07 Georgetown 350DS has an old Voyager B&W camera and an old Tube style Monitor mounted in the dash. I have a few questions about how to fix and replace this system.
1. My current review monitor is mounted high up on the back of Motorhome just below a plastic cap. No idea where the wire goes so no idea how you could fish a new wire through that plastic cap and down along the fiberglass? Any idea how to do this ?
2. My old tube monitor is going to leave a large hole in the dash. I'd like to mount the new camera in the same hole wher this camera was mounted. Any ideas on how to fill this hole and make it look decent and not like a hack job?
Thanks. Any help or ideas especially about running the new wire would be appreciated. That's going to be the big challenge.
No offense but you got that backwards
The Monitor is the tube display in the dash
The camera is the device in the back
As long as everything is working, you get a camera signal up front
Then the cabling is good
You most likely do Not need to pull new cable
You just need to put adapters on the cable to change the wiring connections for the new system
Install new camera in back
Remove dash display, mount new flat digital display over the hole, cover hole with new display monitor
Lots of people have done this
38,782 PostsLatest Activity: Aug 31, 2026
