dougrainer
Feb 10, 2017Nomad
You can NEVER route any cable inside the roof or Roll wrap area. There is no unblocked channel. If you decide to replace the cable, you run it along the chassis frame and then up thru the back cap. either on the corners or if you have a rear window, pull the window to see if you have a cavity to run the cables up. Usually, most motorhomes can have the cable run up either side corner of the rear cap. Doug
38,782 PostsLatest Activity: Aug 31, 2026
