Dale_Traveling
Mar 19, 2015Explorer II
Fading image as described is pretty much the CRT going out. LCD monitors are very in expensive on either eBay or Amazon. You shouldn't pay more than $50. The problem you will have is the size might not be a direct fit, as I found when I replaced my monitor. Add a spacer cut from 1/8" ply and hot glued the monitor frame in. Good fit side to side.
I have THIS ONE. Use the second video input via a wireless to a camera on the back of the toad.
38,782 PostsLatest Activity: Aug 31, 2026
