rgatijnet1
Oct 07, 2019Explorer III
Cubanredneck wrote:
Well it gets worse. Looks like the harness has been discontinued by Ford and searching the internet gives no results. Ford part # 5U9Z12A581AA Per ford its the engine and transmission harness together. Not even sure what to do at this point. Mechanic states splicing them may or may not work but he knows for sure if it does work there will be issues due to the change in wire resistance.
So disappointed. How can a coach that's only 12-13 years old have discontinued parts.
First off I would find another mechanic. No offense intended but apparently this mechanic does not know about electrical issues and he just doesn't want to do the job.
In any case, a properly spliced/soldered wire using the same gauge or larger has the exact same resistance, or less, than the existing wires. After all, you are just inserting a short splice, not replacing 100 feet of wire.
Soldering of wires is not rocket science and many mechanics versed in electronic issues can deal with it easily.
I have repaired electronic equipment since my days as an electronic technician in the Navy. Automotive wiring is a piece of cake.
38,777 PostsLatest Activity: May 20, 2026
