Cubanredneck
Oct 03, 2019Explorer
Bad Dog = No Start and No shifting of Transmission
Hello RV community,
So was about to leave on a trip and went around the corner with the coach only to find that the transmission would not shift. Checked the oil level and found it to be ok. For some reason decided to check under the coach to find that our dog decided to chew on the transmissions harness destroying 80% of the wires. I decided to splice the wires back together to see if this could get me to the shop but it didnt work. After splicing all the wires(Color Coded) the coach would not start.Obviously it had to do with what I did since it had started before. after checking everything i found no issues with the splices so I crossed the starter and fired up the coach. I had no choice as i was on the side of the road. My question is to all can the harness be spliced? I was reading that since it sends signals any change in the wires resistance can cause a problem. I drove the coach over to a shop in first gear since it was only a mile away and waiting to see what he says. Hes a friend and felt that they could be spliced. Does anyone have a wiring manual for a 2007 F53? Is the transmission a standalone harness or do i need to replace the entire harness? The shop is backed up and could take a week before he looks at it. If i could find a harness id replace the entire harness just in case.
BTW the Tow/Haul light is now flashing and the speedometer no longer works. Im assuming its the computer coding out. Ford requires a special computer from what im being told to read the codes.
Any help or advise would be greatly appreciated.
