daverl3's avatar
daverl3
Balance rear tires on class A?
I am getting ready to replace the tires on my class A pusher.When quoting the price for installation, the dealer seemed surprised that I wanted the rear duals balanced. So now I'm wondering how much difference it will make. Any one with experience both ways?
  • They all spin so they all should have some form of balance (IMO). My first rig (97 Winne Vectra - gasser) used weights on all 6 tires. My current rig (DP) originally had powder and when I replaced the tires they recommended beads, claiming that powder will clump should moisture get into the tire. All the methods have worked for worked well for me over several years.
    Lou
    05 Travel Supreme Envoy
  • They put Equal in the last set of tires I bought (truck shop). They're supposed to put special valve stems in that have a screen to prevent the Equal (basically sand) from clogging the valves. Next time I'll do beads. A couple of times over the winter I deflated a tire by checking the pressure and the vale got stuck.
  • I have a 96 Southwind. I've never balanced the duals or tag tires. Just the steer tires. No problems.
    Maybe a pusher is different, I don't know?
    When I said I balanced the steer tires, I mean beads. They did a good job.
  • I would throw a handful of balancing beads and not worry about it.
