viajante's avatar
viajante
Balancing of tires
I will be replacing my tires soon. I have a question about balancing. Which is a better balancing procedure........ spin balance or equal ?
Also..... should you balance all six or just the two front ?
  • I prefer the DynaBeads made especially for RV's. These are larger ceramic beads that do not require special valve cores and work well with a TPMS.
    The DynaBeads keep the tires balanced at all times even as the tires wear or if you pick up some mud on the rim. For the cost, I balance all six tires on my coach.
    Balance all tires..!
    Ive had great balancing done with Equal....and Ive had great balancing done with bubble balancing on a spin balancer and added weights. If the operator knows what they are really doing...either method works fine....if they dont know what to do or are sloppy...you just get a mess
