rgatijnet1
Jul 05, 2016Explorer III
FloridaNative49 wrote:
the tech's comment was that the ABS sensor was "burned out"??
I'm guessing that the sensor is probably less than a $100 part that you could change yourself. On my WH chassis the ABS sensor is $75 and I can change it in about 5 minutes without any tools. The old sensor pulls out, unplugs, and the new sensor pushes in the hole as far as it will go and the electrical plug is connected. No adjustments needed.
I'm sure that someone will post that has changed the sensor on a Ford.
