- BumpyroadExplorer
wolfe10 wrote:
Bumpy is correct. The 50 amp outlet should be installed with the center round (ground) at the TOP so that the cord can hang down.
well I wasn't correct for the first time, but w4phj was.
bumpy - wolfe10ExplorerBumpy is correct. The 50 amp outlet should be installed with the center round (ground) at the TOP so that the cord can hang down.
- BumpyroadExplorer
w4phj wrote:
Simply tell your electrician that you will plugging in a electric stove. Have him
install the outlet upside down so that the ground pin is on the top. This will allow your RV cord to hang down as if you were in a camp ground. .
I made that mistake when I installed a 30 amp outlet on the rear of my garage. the outlet cover was hinged at the top of course and upon first use discovered the plug wouldn't go in. :)
bumpy - bdpreeceExplorer IIJust had a 50 amp installed by an electrician in Yuma AZ. Run was approximately 45 feet buried in the ground all in schedule 80 conduit. Total cost was just under $1300.
- w4phjExplorerSimply tell your electrician that you will plugging in a electric stove. Have him
Installation expense will vary greatly depending on local codes, distance, and labor expenses such as digging a trench or penetrating cement. - rgatijnet1Explorer IIILike everyone else that has a 50 amp RV, I have 240 volts INSIDE my coach at my main breaker panel. That 240 volts is split as it runs through the 50 amp double pole MAIN breaker and this supplies 120 volt power to all of the various electrical components and outlets used in my coach, with each having it's own 120 volt single pole circuit breaker.
SOME, but not all, RV's do use the 240 volts for items like the clothes drier. My friend's Liberty Prevost uses 240 volts for his clothes drier, his oven range, and for his underfloor heating. He still uses the same 50 amp plug in the RV park that we all use and that the OP is installing. - Old-BiscuitExplorer IIIOK.......think by the second correction 'coolmom42' got the idea.....Six not necessary
At least it OPENED the discussion about 50A 120/240VAC and 30A 120V or 240V
OPs brother is having a 50A receptacle added.
So bonded or backyard electrician would have to REALLY mess up (work hard---intentional) to screw it up
4 wires (2 hot/1 neutral/1 ground), NEMA 14-50R receptacle and 50A Double pole CBs ----electrician will be OK
- usersmanualExplorer
coolmom42 wrote:
Make absolutely sure that he and his electrician understand that it is 50 amp 120 V---NOT 50 amp 240 V! Otherwise it will cost you a LOT.
your incorrect
The 50 amp RV plug is the same as a 50 amp stove outlet. 50 amp RV plug is 240V in reality then it splits into two 120V runs as it enters the MH
you can take the 240V stove out of your kitchen and plug it into a 50 amp RV outlet and the stove will work just fine
-its a 30 amp welder plug in that u stay away from as its truely 240V only
that's why its 4 wire cable used 2 black- one white and a ground - hankoExplorer
sorry to inform you, but a 50 amp Rv service is in fact 240 volts. Bank on between 4 and 8 hundred depending your situation. - STBRetiredExplorerAbout $175 in materials in mine. Took 5 hours because the conduit was buried outside because of doorway. If no trenching, then maybe 2 1/2 to 3 hours. At $100 per hour for electrician, figure around $500.
38,780 PostsLatest Activity: Nov 22, 2015
