- wolfe10Explorer
coolmom42 wrote:
Make absolutely sure that he and his electrician understand that it is 50 amp 120 V---NOT 50 amp 240 V! Otherwise it will cost you a LOT.
Completely INCORRECT.
As the post following this post shows:
TWO, repeat TWO hots from opposite sides of the breaker box. 240 VAC between them!
Two outer straights are the hots.
Center round is ground.
Center straight is neutral. - J-RoosterExplorerI did mine (my son wired it in) and everything was around $150.00
- tropical36Explorer
Say what???
It is in fact 240/120vac and wired the same as a residential electric range.
Now if you're using and wiring up a 30amp outlet (receptacles and/or outlets aren't plugs by the way and for those who have trouble differentiating males from females...lol), you certainly wouldn't want to wire it like an older residential clothes dryer for 240vac and where the problem lies with those who claim to be licensed professionals.
These are most definitely 120vac and consist of one hot, one neutral, and one ground.
Funny word, professionalism and in many instances, if you really want something done right, then you might just have to do it yourself. - azrvingExplorer.
- jorbill2orExplorer II30 amp plugs are the ones that can be wired wrong .. as 240, not "50" amp plugs which are all 240 . most RV's use them as two separate 50 amp 120 legs .. part to half the panel the other to the second "half" and not combined although the could be.
To the question . I had a bid if 500 bucks to install 20' from the garage box outside of garage wall but depends on your area. - gemertExplorer
muskrat49 wrote:
Ignore this one. All 50 amp RV receptacles are (and MUST be according to the National Electrical Code) 120/240 volt. Look at other threads for details.
I wouldn't ignore either of these. They are both right. I'm not an electrician but when a storage lot put in a 50 amp connection for me they screwed it up and did 5K damage to my coach. I am more knowledgeable now than I was then and I believe they used a 30 amp, 3 connector cable. I think 30 amp is the most dangerous because it is very similar to an old style 240 dryer type plug. They either did not connect the neutral (bad) or connected both legs of the 120 VAC where one leg and the neutral were supposed to be. I think your biggest take away from this is check what they do your self. I had a 50 amp installed on the side of my garage today. When he got done he put the meter across the connections so I could see and everything was right. I insisted in putting my surge protector on so I could see it the same way I do when camping. As soon as I plugged in to the plug it made a loud bang and blew the breaker. It turned out that he had a connection behind the plug and when I plugged in it forced it into the ground bar. Moral of the story, go through all the steps yourself and make sure it is right. Cost was about 350. I had some other work done so can't say exactly. Good luck. - muskrat49Explorer
Ignore this one. All 50 amp RV receptacles are (and MUST be according to the National Electrical Code) 120/240 volt. Look at other threads for details. - BumpyroadExplorer
plug in your EMS and check it out before your RV is plugged in.
bumpy - RoyBExplorer IIThis is why you want to have a licensed BONDED Electrician... His insurance will cover what gets burned up if it is wired wrong...
Even when you show up be sure to check the PIN OUT readings yourself with a Multimeter... You may be the first one to use it...
They should do exactly like shown here...
RV 50AMP Service
RV 30A/20A/15A Service
Pictorials from NOSHOCKZONE
If you DON'T see exactly what is shown here DO NOT repeat DO NOT plug your shore power cables into the receptacles... Several appliances may go up in smoke even tho they may not be turned on... Being family it is hard to point fingers...
Just saying
Roy Ken - coolmom42Explorer IIMake absolutely sure that he and his electrician understand that it is 50 amp 120 V---NOT 50 amp 240 V! Otherwise it will cost you a LOT.
38,763 PostsLatest Activity: Dec 05, 2025
