Jim
Jul 06, 2016Explorer
Also know that rotors seldom need to be turned unless you've got a metal scraping metal from a worn out pat situation. Mine went 165,000 before they needed it. And with yours at 18K, it's unlikely. They need to be replaced even less often with the exception of being cracked, warped, or blued from overheating. Even then, small blued spots aren't cause to replace a rotor. If you ride your brakes down hills, that might cause problems though.
