J-Rooster
Jul 07, 2016Explorer
FloridaNative49 wrote:A burned out sensor is quite common if the driver constantly hits the brakes hard or over using the brakes (going to fast downhill with constant braking) it causes the sensors to overheat, keep this in mind and downshift on hills. Also a rule of thumb on brake pads you should replace the rear pads after the front pads have been replaced once. Very rarely have I seen both sets needing to be changed at 18,000 miles. Good Luck, Rooster
the tech's comment was that the ABS sensor was "burned out"??
