Corkey05 wrote:
From Federal Trade Commission on the Magnuson Moss Act.
FTC - Magnuson Moss Act
Will using 'aftermarket' or recycled parts void my warranty?
No. An 'aftermarket' part is a part made by a company other than the vehicle manufacturer or the original equipment manufacturer. A 'recycled' part is a part that was made for and installed in a new vehicle by the manufacturer or the original equipment manufacturer, and later removed from the vehicle and made available for resale or reuse. Simply using an aftermarket or recycled part does not void your warranty. The Magnuson-Moss Warranty Act makes it illegal for companies to void your warranty or deny coverage under the warranty simply because you used an aftermarket or recycled part. The manufacturer or dealer can, however, require consumers to use select parts if those parts are provided to consumers free of charge under the warranty.
Still, if it turns out that the aftermarket or recycled part was itself defective or wasn't installed correctly, and it causes damage to another part that is covered under the warranty, the manufacturer or dealer has the right to deny coverage for that part and charge you for any repairs. The FTC says the manufacturer or dealer must show that the aftermarket or recycled part caused the need for repairs before denying warranty coverage.
Take the time to investigate the entire document, not just the above quote.
Banks works very close with vehicle manufacturers to avoid warranty conflicts. There have been thousand of Banks kits sold and never heard the installations creating a warranty conflict.
Dealer denies warranty coverage.
You say - "Wrong! MM Act prohibits same!"
Dealer says, "We are correct - *you* are wrong. Prove otherwise".
Good luck. (Who has the rooms full of attorneys?).
May vary from dealer to dealer - but once denied, it's entered in history.
"Banks working closely with mfgrs" - and/or others success is immaterial.
Probably never have a problem - but if you do, and expect warranty coverage........:@
