bjones3211's avatar
bjones3211
battaries not holding up
I went dry camping for the first time in my new to me 2014 class c and to my surprise the batteries did not make it thru the night the next night the only thing I left on was 1 led light and the refrig. when I got up same thing batteries volts around 5.5 is this normal?
  • Switched my 12 volt car batteries for deep cycle Trojans, huge difference. I had the same issues as poster, batteries were weak.
  • bjones3211 wrote:
    thanks for all the feed back yes the refrig was running on LP. guess I need to have the batteries tested the bad side is I don't dry camp much hate to put out a lot of money just to have them go bad again.
    I have 2 12 volt deep cycle batteries
    If you mean marine deep cycle batteries then they are just slightly better than starting batteries and are not deep cycle batteries. But they should be OK for a night.
    How did you recharge for the second night?
  • Unless your old batteries test bad under load, I'd suspect a short or some item drawing too much current during the night. Appliance controls and alarms draw some 12 volt dc current from house batteries
    If you disconnect the positive or negative cable on the house battery and connect an ammeter to the cable and battery post you may see how many amps are still being drawn with everything apparently shut off. If you are not able to test, have it tested by a trusted RV repair.
    Was there a light left on in your storage compartment?
    Did you have the furnace or furnace blower or ceiling fan running overnight?
