I have a 2014 Fleetwood Storm Class A all batteries are discharging within 4 to 5 days even with everything off. I have no idea what is causing the discharge. Anybody have an idea? DB
If you have a Ford chassis, make sure the Dimmer for the headlight switch is OFF. The Dimmer is the wheel/knob that turns the Speedo cluster lights brighter. Like a car, the "Indent" will turn on a relay for the Dome light. You do NOT have a dome light, but that relay will engage and will draw current, even with no light. Doug
