Redram99
Apr 24, 2018Explorer
Batteries not charging while chassis engine running
Hi all
I have a 2010 triple e senator class c. Ford v10.
Recently I noticed my house batteries weren’t charged after a long road trip. Even when the v10 was idling the house battery voltage didn’t match the chassis battery voltage. As soon as I plug into shore power or fire the genny the house batteries start to charge.
In my battery compartment I have a 12v dc coil and a bi directional isolator relay delay.
I have 14v to one side of the coil while the engine is running but it doesn’t continue thru the coil to the house batteries. It appears that the bi directional isolator “runs” the coil??
As a quick fix, I jumped a wire direct from the chassis side of the coil direct to the house batteries so they would charge while driving. Quick fix but now the house is also running off the chassis batteries which could cause issues(dead battery and no engine start)!!!
Would it be the coil or the isolator that is broken? How do I figure it out?
Ps. I am probably the worlds worst electrician...
Thanks in advance.
Jamie
Thanks in advance.
Jamie
