tropical36
Nov 01, 2015Explorer II
dougrainer wrote:tropical36 wrote:NowWhere2 wrote:
Pulled a bone-head move yesterday and pulled the batteries out of our brand new FR3 30DS while the retractable step was in :S I've done this before, but i failed to bring out my 'cheat sheet' from prior years to remind myself not to do that!
so i hooked one battery back up, but steps would not move, I tested the slide out and it had power, so my battery was hooked up OK
Isn't there a manual way to bring these steps in without disassembling them?
My steps work from the chassis starting battery and the slide comes from the house batteries.
You POSITIVE about this claim? National always connected the steps to the coach batteries. To test is simple. Turn the coach battery disconnect OFF(NO Shore power also), then try to operate the steps. IF they operate you indeed have the steps to the chassis battery. Doug
Yep, more than positive and yes they still work with the house batteries off. It actually takes a little more than a test like that, when checking out electrical systems. For instance, my slide still works with the house battery switch off, as well and even though it's fed from the house batteries.
