ron_dittmer
Apr 30, 2015Explorer III
Well I finally converted from 12V to 6V. My old 12V batteries were in a very nice latching roller glide tray for ease of maintenance, but the 6Vs are taller so I replaced the tray with a flat stock steel plate. Because maintenance is now more difficult, I went with sealed AGMs.
Of coarse now that I am done, someone tells me AGMs may require a higher charging voltage. Is there any truth and concern to that?
Anyway, here are the details of my conversion, shared in my home town Phoenix Cruiser forum.
Ron
One of our two 12 volt batteries failed, same as with our first set. When one goes bad, acid boils over and makes a mess, and of coarse a serious loss of battery reserves. Good practice says to replace both batteries.
With all the discussion on the benefits of 6 volt batteries, I wanted to give them a try. I shopped around and found Sam's club to be a good supplier of 6 volt lead acid and AGM batteries by Duracell. The AGM is twice the cost that of lead acid at $180 per battery, but given my newly created limited access situation, I got the AGM batteries HERE.
Given all 6 volt batteries are much taller, I had to replace my slide out battery tray with a flat sheet of metal to gain height inside the battery compartment. I found a nice piece of black painted metal being thrown away at work which had a couple of bends that benefited me. I bolted "L" bracket material from a home improvement store to cradle the batteries.
I mounted the brackets to the tray, then the tray to the battery compartment. I then removed the front bracket to slide in the two 6 volt batteries, connected them up nicely, then replaced the front bracket.
Without being able to slide out the batteries, it was difficult to make the connections with a ratcheting box wrench. I used both original short battery cables in between the two batteries for a robust electrical interconnect. As I had originally, the red/+ terminal is on the right side, the black/- terminal on the left side. I used the screw terminals on the batteries to keep the large terminals free to use my secondary battery charger as I like to do at times for quick charging with the generator. Because of the limited access, checking water level is not practical which is why I selected the maintenance free AGM batteries. The next time I disconnect them is when they get replaced.
With the door closed, you can see the front most "L" bracket which is why I painted it black as not to stand out.
I am hopeful that two 6 volt batteries hooked up in series will perform better and last longer than two 12 volt batteries hooked up in parallel.
Ron
