ron_dittmer's avatar
ron_dittmer
Explorer III
Oct 13, 2014
Batteries: Two-6V In Series, or Two-12V In Parallel ???
Before spring I will be replacing our two 12V Walmart coach batteries. Our 7 year old rig has it's original Tripplite 2000 watt inverter/charger similar to THIS ONE. I was thinking of replacing the two 12V batteries with two 6V batteries as these forums seem to favor 6V in series compared to 12V in parallel. I called the maker of my inverter. The technical person there told me two 6V batteries in series will work just fine with the inverter.
But I have a concern switching from two 12V to two 6V batteries, this in regards to the drop in amp hours. Assumed identical amp-hour ratings, two-6V will be 1/2 that of two-12V. Currently our inverter adequately supplies power to make a pot of coffee and watch TV with a sound system. Will two-6V batteries in series be able to meet those demands the same as the two-12V?
In General....
With a rig like ours that has a 2000 watt inverter and no solar panels, what benefits and drawbacks might there be in using two 6V batteries in series? Keep in mind that we almost never hookup to shore power. Battery charging is done while driving and when parked for days at a time, running the generator.
Will it take more time or less time to charge 6V batteries?
How does the physical size of a 6V battery compare to a 12V? I hear they are taller. Do they take up the same footprint in our battery tray?
I am especially interested in hearing from people who made the switch from 12V batteries to 6V. Also, I'd appreciate your input on the best 6V batteries to buy, where to buy them, and what I could expect to pay per battery.
Thanks!
  • We, too, are charter members of the no-hookups-club. I use 4x300Ah 6v batteries. As far as I know, it makes no difference whether you use a 6v battery or a 12v battery so long as you end up with the number of ampere hours you need. People started using 6v golf cart batteries as they were an easy way to find true deep cycle batteries, as opposed to starter batteries.
    (For the technically inclined, there are neither 6v nor 12v batteries, only 2v batteries, either three or six to the case.)
    So, connecting my 6v batteries in series/parallel, I end up with a 12v, 600Ah battery bank which gives me 300Ah usable.
    The type of battery you use is VERY important. For camper use, you want true, deep cycle batteries. That is big, thick plates and lots of acid.
    AGM batteries are more expensive but can offer advantages of less maintenance, better vibration resistance, and the option of mounting sideways.
    When you start getting over 400Ah, you really need solar or shore power to assure a full charge. Even with the special wiring on my truck, it is hard to drive long enough to fully recharge a big battery bank.
  • If you are comparing 2x group 24 and 2x GC2, the GC2 will have ~30% more amp hours.
    Of course you can get larger 12v and higher rated 6v.
    6v tend to be a bit taller so make sure you have the headroom.
  • Ron..I have had both set-ups and have gone from 12 to 6 in one of them, I currently use 3 12's. I can't go all techy on you here. I haven't the foggiest idea of the numbers. What I go by is...does it work?
    My power consumption is as follows: I have one small inverter, a 600W that I run almost constantly to charge computer,camera, drill, flashlight batteries. I do not use lights sparingly and have no LED's. If needed I run my furnace like a normal life thing. I live in northern BC and that means that the sun is lower than in the southern parts of the US as far as solar collection is concerned.
    I seldom am in a plug-in situation and have never had a problem. I did work for the NPS in the Mojave during a 10 week winter (cloud, rain, snow) and again, never ran short of juice.
    I do have 250W of solar, and currently 3 12V Napa Deep Cycle's that I bought 3 years ago in Needles.
    Meeting your own personal needs will depend on three things. What your own personal power habits are, how much solar you have and yes, the batteries. Get LOTS of solar. That will ensure your batteries get charged no matter what the weather conditions. If I had to choose between 2 6V and 3 12 V's..and that WAS my choice..I'd take the 12's every time. If I had the room, but I don't, I'd opt for 4 6V's. The 6's will be taller and much heavier.
    I'd suggest looking at NAPA because if you have a problem, they are 'everywhere'. And shop at a NAPA store..not a dealer. The pricing is quite different.
    Gary Haupt
