- free_radicalExploreris anyone here familiar with these
http://www.bruceschwab.com/advanced-energy-storage-systems/firefly-energys-oasis-group-31/our-firefly-battery-dealers-in-north-america/ - J-RoosterExplorer
theoldwizard1 wrote:
Thanks Wiz!J-Rooster wrote:
AGM's didn't work for me due to I didn't drive my RV enough! Even with a constant trickle charge.
It is a little known fact that no lead-acid battery "likes" to be on a constant trickle charge for weeks on end. Connect your trickle charger to a cheap mechanical lamp timer and set it to run the charger 1-2 per day.
If possible, find someplace to store your batteries <80F. Outside or in a garage in AZ is too hot. - dstock50ExplorerI did WM deep cycle marine parallel for Cat C-7, works fine, will do the same when the four six volt go bad.
- usersmanualExplorer
Johnny G1 wrote:
13 yrs now on Trojan T105's and they have water mizer caps and are charged by solar at all times, haven't let me down yet, I do water them once a yr.
could be. most likely the last five years or more they would have pretty much useless as far as lasting more than a hour two when off shore power or being charged - Johnny_G1Explorer13 yrs now on Trojan T105's and they have water mizer caps and are charged by solar at all times, haven't let me down yet, I do water them once a yr.
- theoldwizard1Explorer II
usersmanual wrote:
your the only person in the world that went 12 years on Costco 6 volt house batterys or any battery used for such usage and only adding water twice in that time period
I went 14 years on the original equipment battery in my E150.
I did clean and water it (yes, it was a maintenance free battery) about once ever 12-18 months. - theoldwizard1Explorer II
Kayteg1 wrote:
For coach batteries IMHO it is hard to beat golf-cart batteries from Costco or Sam's club.
Last set I bought at Sam's for $46 a piece was still usable after 12 years.
Having advanced inverter/charger I recall adding water only twice in 12 years.
YMMV
WOW ! Amazing !! I think you should have upped yor watering cycle, but you can not argue with success. - theoldwizard1Explorer II
If possible, find someplace to store your batteries <80F. Outside or in a garage in AZ is too hot. - usersmanualExplorer
YMMV
your the only person in the world that went 12 years on Costco 6 volt house batterys or any battery used for such usage and only adding water twice in that time period - +1 for Lifeline
38,761 PostsLatest Activity: Nov 18, 2025
