den60
Aug 22, 2013Explorer
Battery acid dripping on floor pan
Hello everyone, I have a pile of white dried battery acid building up on the floor under a + cable. I thought maybe someone might have a suggestion as to what to do here. I had the RV shop look at this and they told me that this was normal. I'm having a hard time believing that. I asked the shop if the cables needed cleaned and they told me they looked OK to them. Another hard time believing. OK, the cable that comes from the + post on the battery loops down and back up to a fuse, (I believe) on the wall and then from there it goes inside the RV frame. I am plug in to shore power and I have the inverter turned off but the manual says that it will still charge the batteries. It's a xantrex 2000 watt. I don't know a whole lot about those things but I'm hoping that someone on here might be able to help me out with what's going on here. When I ever figure out to post a picture on here, I will do that. It sure would help. Thanks....
