RoyB
Oct 20, 2016Explorer II
Check out the line of diamond plate metal battery boxes FORKLIFT has on their site...
I have made up a couple of metal battery boxes for the GC2 size 6V Batteries using the 48-inch truck bed side mount metal boxes but this would not work good for GP31's...
Just remember if they are wet batteries you have to provide for venting battery fumes when charging and also a drain to earth ground in case you boil out fluids by over charging...
When mixing with other batteries you have to use equal lengths cabling so each battery demands the same charging currents so they all will charge up at the same rate and time... Have never mixed AGM and wet batteries together at same time for charging... You may have to charge each bank separately to keep a badly charged up bank from pulling down a good charged up bank...
I like to use the BLUE SEA Marine DC electrical products for projects like this...
Roy Ken
Roy Ken
38,766 PostsLatest Activity: Jan 10, 2026
