Kensram3500's avatar
Kensram3500
Battery charger
Have a Lance 2016 995 TC. Wanting to add a stand alone battery charger. It came with 2 group 24 batteries which I may change to group 27's when the time comes. I know that the converter is not the best for fast charging. I don't want to run the on board generator long enough to charge the batteries. I have a Honda 1000 generator that I will bring along for the purpose of charging the boat batteries along with the camper batteries when needed. I want a good charger that will help the batteries last. I do have solar and am not wanting to add any more. No problem carrying the Honda or gas. If needed I also have a Honda 2000, Any thoughts. Any other place I should post this question thanks
  • Mandalay Parr wrote:
    Seems redundit to drag around another generator and charger. Your 2016 Lance probably has a decent converter and generator. I'm no expert but a real fast charge may not be the best for battery life.
    This is my initial gut feeling too. Especially since there already is some solar present.
    More details are needed....like what make and model converter/charger do you have ? Hopefully it has a relatively fast bulk charge mode and your onboard gen will use less fuel when lightly loaded.
    I have found that I need/want AC power enough hours a day that it also keeps the batteries near to topped up as a side benefit.
    If your TV/satellite equipment is AC powered I'm pretty sure that keeping the batteries charged will not be a problem.
  • Seems redundit to drag around another generator and charger. Your 2016 Lance probably has a decent converter and generator. I'm no expert but a real fast charge may not be the best for battery life.
    I'm sure others will chime in.
