Dave22
Jul 19, 2015Explorer
Booster switch enabled locating the solenoid isolator. Pressing the booster sw retracted the step. With engine off, volt into isolator = 12.80, out of iso = 12.47. With engine running and charge voltage of 14.9, volt into iso = 14.9, out of iso = 12.79. I think there may be more than one problem. The battery disconnect is one of those momentary contact switches and the position of the switch did not effect the above readings. I still do not know the resolution to this problem and I hope this helps. Thanks to you all.
38,763 PostsLatest Activity: Dec 05, 2025
