Vulcan_Rider
Jul 19, 2015Explorer
Dave22 wrote:
Pushing the booster button with the engine on increases the voltage out of the isolator to 14.xx from 12.79. Voltages were measured at the isolator.
The relay/solenoid/isolator often exhibits a high resistance due to burnt contacts before it fails completely.
Your readings indicate that it's contacts aren't making a good connection.
If you search around on here a bit you might find other threads that talk about how to "fix" that solenoid......if you are into doing things like that. In my book, a new one is a better solution.
38,763 PostsLatest Activity: Dec 05, 2025
