Tom_Barb's avatar
Tom_Barb
battery charging
how long should we stay on Float charging before change. ??
We are now about 3 months of no change.
13.3 Volts steady
Should I disconnect for a while, and allow the batteries to disconnect for a while.
    Some "tenders" turn off and on but most just drop down to the float level, which is what yours has done, and stay there more or less forever.
  • There is some evidence that cycling helps batteries last longer. I'd suggest that one day per week you run from the battery bank.
  • Will not hurt to run overnight on battery power once every 30 to 90 days.
    IMO a few cycles now and then is fine and proves what is working.
  • 13.2~13.3 is good forever. You can forget about it!
    I will check my water levels in the spring and very little, if any, will be needed.
    S
  • Float charge at that voltage should be fine......but if a wet cell just check the water level occasionally.
