kidkasha wrote:
1999 Fleetwood Discovery. Is it possible to chancy 4 6 volt batteries the six volt batteries to 2 12 volt batteries? Has anyone done this successfully, and what are there any issues.
No problem and with our coach, it originally came with 4 12v AGM Group 24 batteries. Dealer for previous owner, changed them out to 4 6v wet cells. I put them back to original specs., although, not so sure if having used 4 6v AGM's would have provided more power or not. Depending on the sizes and space available actually and it's just a matter of changing the series/parallel connections to straight parallel. Naturally, two 3/0 jumpers got lost in the process, so had to make those up to complete the install and found out that large crimp on lugs aren't readily available, unless from a electrical distribution house. At least not from Home Depot and the like.
If in doubt with the connections, seek help and/or check the output voltage before connecting up the last lead, which should be your neg. ground.
In my case, I have quite a few neg grounds returning and quite a few plus pos. going out, as well.
