JD38's avatar
JD38
Battery Control Center solenoid dropout voltage
2001 Fourwinds, Gas V-10, Intellitec BCC. Ever since installing new batteries I can not get the chassis solenoid to latch without starting the engine. But the coach one does latch without the engine running. I measure 12.44 V across the coach batteries w/o engine running. I can hear both solenoids "click" when I activate the DPDT switches. There is voltage ( 1.19 V as I recall) across the test points in the BCC when the switches are activated. If I leave the coach DPDT switch in the "on" position and start the engine the coach solenoid activates and all is well. (I still get 12.44 volts at the coach batteries which is a little bit bothersome..why isn't the alternator charging them). I did NOT charge the new batteries when I put them in thinking some driving would fully charge them. If I turn off the engine the coach solenoid unlatches after about 15 seconds but the engine solenoid does not. I am thinking that my batteries are not fully charged above the unlatching voltage of the chassis solenoid. But??? why doesn't the chassis solenoid unlatch. I read somewhere that 12.8 volts are required to keep them latched. Do I just need to get my batteries charged above 12.8???? (I forgot to note what Intellitec revision of BCC I have.) Ty for any help
