OnaQuest
Jun 06, 2013Explorer
When you push (and hold) the "cross connect" switch, does the relay drop out after a few seconds or will it stay energized as long as you hold the switch closed? If it drops out during this procedure, it's probably a heat related problem with the relay coil and needs to be replaced.
If it holds, and doesn't drop out, then you know the problem is with the circuits/conditions that energize the relay or you converter voltage is dropping too low to keep the relay picked.
Check the output of your inverter/charger with a VOM. It should remain above 13.2 at all times when plugged in. Also, check your battery voltages after they have rested (not plugged in for awhile) They should retain a voltage above 12.4 or 12.6 for a very long time after charge voltage is removed. If they rop too fast, they are probably weak/bad
38,707 PostsLatest Activity: Feb 18, 2025
