Leno's avatar
Leno
Battery Disconnect Solenoid
Several months ago I was having work done at an RV repair place.(would never return to them) They said my solenoid for the battery disconnect was bad and removed it. They temporarily connected two wires ( or so they said). I would like to replace the solenoid. I know it was under my bed but have no idea where. Are all the solenoids the same, if I want to order one? I have a 2001 Four Winds RV. Is it a simple fix?
  • WyoTraveler wrote:
    continous duty solenoid
    The solenoid in the above link is not a latching solenoid and would not be a suitable replacement for the solenoid in my four winds.
  • What model Four Winds do you have? You probably have the same solenoid as me. Mine is located under the bed, on the curb side, behind the power distribution panel and converter. I have to remove a cover to see it.
    I would have to go out to the MH and look to tell you any more about the solenoid. I know it is a 12v latching solenoid.
    Depending on what they did when they removed the solenoid, it shouldn't be a difficult fix.
    All battery disconnect switches I ever seen do not require or have a solenoid in their circuit. If your BD circuit requires a solenoid and it was removed, your BD won't engage or disengage without it being operative.
    A solenoid is simply an electrically operated switch that engages or disengages another electrical switch,as as your engine starter.
    Check and see if you can see where they connected the wires (if they in fact did).
    One bit of advice I always give in these types of situations is to always ask for the part (s) that are supposedly replaced back.
