kioticoachman
Sep 18, 2021Explorer
bobndot wrote:
Make sure the connections on the relay solenoid are clean. The solenoids are not expensive, i would buy a new one and try it. Its a common enough fix in these systems, if that doesn't help, keep it as a spare. Its a good part to have on hand.
I'm presuming that the relay solenoid, you mentioned, is located in the battery compartment under the step to the right with the cable connections.
Had a SC moment ... Maybe this might help, and I should of mentioned this before but with the generator running the battery connect switch will activate. However the DC/Coach power does not activate otherwise.
Will check this out further ... Thanks for the suggestion.
38,783 PostsLatest Activity: Sep 24, 2026
