sew0177's avatar
sew0177
Battery Disconnect Switch
I want to install a battery disconnect switch on my 04 Revolution but want to make sure it can handle the amperage generated by the 4 house batteries. I have searched the board and found information about using disconnect switches but not the size or type.
Any suggestions?
  • Not sure if wiring diagrams are available from Fleetwood for your rig.
    Get your serial number and vin number, then contact them for wiring diagrams.
    I haven't seen any Fleetwood MHs without battery disconnects for the coach.
  • rvten wrote:
    Surprised your MH does not already have one.
    lots of Diesel A do not. my 08 allegro bus does not have a manual main house battry disconnect.it has a 12V bypass but not a direct manual disconnect as what the op is asking about
  • Surprised your MH does not already have one.
  • enblethen wrote:
    You didn't say whether you wanted an electrically or manually operated. Surprised that your rig is equipped with battery disconnects.
    This unit from Intellitec should handle your needs.
    Intellitec Big Boy
    Remember that you should not be connecting or disconnecting under a heavy load. The circuit to the inverter if equipped should not be going through the disconnect.
    He must not have a switch(disconnect(?) otherwise he would not be asking such info/.The problem is if u don't run the inverter/converter through the disconnect your battrys will drain albeit slower they will drain
    I have this exact problem,I have the 12v house shut down but the inverter/converter are direct and batterys slowly drain
  • You might want to look at Flaming River products.
    http://www.flamingriver.com/index.php/products/c0015?gclid=CP_2q5Dy78kCFdgHgQodztEKYA
    Their larger switches can handle 2,500 amps of cranking power. We used one for over 12 years on our 2001 Winnebago Adventurer. We didn't need one with that high a power rating, but did like the mounting brackets and solid connections. They aren't cheap, but they will handle just about any load you throw at them for may years to come.
    Absolutely right. As near to zero as possible. But the switch must be capable of carrying the same load as the main cables.
    That last comment is confusing and, I think, wrong.
    A battery disconnect switch should disconnect the batteries from EVERYTHING.....except a battery tender (solar or otherwise) that you want running all the time.
  • DrewE's avatar
    DrewE
    Explorer III
    What loads are you switching? You need to size the disconnect switch for the current the load consumes, not for the current the battery could theoretically produce. Your battery can producing a short circuit current that's a lot higher than should ever be possibly required of it. A lead-acid battery is capable of doing things like melt wrenches that are accidentally dropped across the terminals.
    If you're switching the main input to your 12V distribution panel (only), you'll never be switching more than the main fuse there or, if it has no main fuse(s), the sum of the branch circuit fuses. Typically this would be on the order of 100A or so, but it could vary depending on the RV and what all devices it's equipped with and how its wired.
    If you have a nontrivial inverter you're running through the disconnect switch, the current rating needs to be a lot higher.
  • You didn't say whether you wanted an electrically or manually operated. Surprised that your rig is equipped with battery disconnects.
    Intellitec Big Boy
