enblethen wrote:
You didn't say whether you wanted an electrically or manually operated. Surprised that your rig is equipped with battery disconnects.
This unit from Intellitec should handle your needs.
Intellitec Big Boy
Remember that you should not be connecting or disconnecting under a heavy load. The circuit to the inverter if equipped should not be going through the disconnect.
He must not have a switch(disconnect(?) otherwise he would not be asking such info/.The problem is if u don't run the inverter/converter through the disconnect your battrys will drain albeit slower they will drain
I have this exact problem,I have the 12v house shut down but the inverter/converter are direct and batterys slowly drain
